- Joined
- Nov 19, 2019
- Messages
- 5
- Reaction score
- 0
After configuring TLS on a sip trunk (which is supported by our provider) the 3CX reports that the certificate is invalid.
01/29/2020 5:55:26 PM - [CM504005]: Registration failed for: Lc:10000(@TrunkName[<sip:[email protected]:5060/TLS>]); Cause: Cause: 503 Certificate Validation Failure/REGISTER from local
From this log i cant really see if its the PBX's certificate failure or the certificate of the cloud PBX on which im trying to connect to.
on using "openssl s_client -showcerts -connect sbc.sc.voipit.nl:5081" i can see that the certificate is validated by digicert and it seems to be verified.
Verify return code: 0 (ok)
I've also inserted the root CA of digicert rapidssl which seems to be valid til 2027
Does anyone experience the same problem? or know where i can look?
