SECURE SIP - Use existing cert
PHit
under Security -> Secure SIP I could provide an certificate and private key.
But I've already an letsencrypt key generated on OS level via acme.
This Key I always copy to /var/lib/3cxpbx/Bin/nginx/conf/Instance1/PRIVATEKEY.pem after renew after 90 Days.
I dont't like to copy the cert and key manual to the webfrontend, is there an path for the cert/key where I culd copy it too?
Bye
Gregor
This is an unsupported scenario so I doubt there is a way to do this, but at the same time, maybe there is. Usually Secure SIP should use the same SSL as Nginx (for the Console and Webclient.)
This happens automatically if you use a 3CX issued FQDN and SSL Certificates,so I am assuming that you are using a custom FQDN.
As Frederick said, there is no officially supported way of changing this, but the files where this is saved in are here:
/var/lib/3cxpbx/Instance1/Bin/Cert/
I advise against scripting something because if you make a mistake with permissions, probably the Management Console will not even start at all, plus after any change you need to restart the 3CX Services anyway.
Yeah, I found this path after I copy the content of the cert and key over the webfrontend.
Wich is the main 3cx Service I've to restart? 3CXSystemService01.service and 3CXPhoneSystem01.service ?
No truble about the permissions, I will set them with the renew script.
All of them:
Bash:
/usr/sbin/3CXStopServices
/usr/sbin/3CXStartServices
aatroxadrian
