SecureSIP is readded automatically
Severin Meyer
As my provider told me, I had to disable SecureSIP because the certificate could not be used to make a connection to the sips server.
(Provider: 3CX is aware of this problem, but cannot solve it)
So I have disabled SecureSIP, and all seems to work fine, until today.:
The PBX has automatically enabled the SecureSIP feature. Therefore the trunk failed to register.
Im wondering, why this is happening, when I manually disabled SecureSIP.
08.02.2019 04:50:00 - Secure SIP (IPv6) is available at ***
08.02.2019 04:50:00 - Secure SIP (IPv4) is available at ***
08.02.2019 04:50:00 - Adding secure SIP transport (IPv4) for ***:5061
08.02.2019 04:50:00 - [CM506005]: Public IP=**** is used for WAN communications through local interface with IP=**
08.02.2019 04:50:00 - UDP transport is joined to SIP multicast group on interface **
08.02.2019 04:50:00 - Folder for SSL certificates : /var/lib/3cxpbx/Instance1/Bin/Cert
08.02.2019 04:50:00 - ** Initializing SIP stack **
08.02.2019 04:50:00 - Local IP addresses detected: [**,****]
08.02.2019 04:50:00 - [CM501006]: Default Local IP address: **
08.02.2019 04:50:00 - Default best-route IP is determined as **
08.02.2019 04:50:00 - [CM501002]: Version: 15.5.15502.6
08.02.2019 04:50:00 - [CM501001]: Start 3CX PhoneSystem Call Manager
08.02.2019 04:50:00 - [CM501007]: * Started Calls Controller thread *
08.02.2019 04:50:00 - Startup completed for pbx:5485/DBProvider
08.02.2019 04:50:00 - [EC200001]: Configuration server is connected:
application:pbx:5485/DBProvider
local:127.0.0.1:47256
remote:127.0.0.1:5485
08.02.2019 04:50:00 - Application connected:pbx:5485/DBProvider
08.02.2019 04:50:00 - Start management threads for pbx:5485/DBProvider
It seems that this has occurred in context of the let's encrypt certificate renewing.
Interesting, there was rumor at some point that secure SIP will be included with the PBX as standard however there has been nothing implemented as far as I know and the release notes state: https://www.3cx.com/blog/change-log/phone-system-change-log/
If this has definitely happened automatically it would of good to hear if 3CX are aware of anything.
Hello @Severin Meyer
Please note that we were able to replicate this behaviour and we will look into this to see if this can be improved. Thank you for reporting.
GothamUser
