Self IP Blocklist
BlueBlazer_tech
SOHO User
While working through updating some Fanvil phones, my server seems to have IP Blocklisted itself into a fully locked out state.
I've encountered accidently IP Blacklisting before...Local addresses had been whitelisted as well.
No amount of IP routing through VPN's or alternative addresses seems to allow me to login, so it seems its some sort of self lock?
Is there a way to clear or reset a self-hosted instances blacklist/temporarily disable it on a selfhosted instance? I'm not outside the bounds of what I would consider normal use, updating newly received phones while doing some minor provisioning.
Active v20 Enterprise License
If your instance is selfhosted somewhere, you need to use an sbc to provision your phones or use routerphones.
Correct, indeed how it has been setup, and all new v20 instances are setup. My question is specific to the IP Blocklist. I don't see how your response is helpful to my question.
"Is there a way to clear or reset a self-hosted instances blacklist/temporarily disable it on a self-hosted instance?"
If you can confirm whether or not there is a flag I can set through the terminal to do the above? Or does it require direct modification to the database to make those changes?
You need to have local access over vpn or something else and log in with a local ip. That's the only way, or just wait..
Any specific reason it would block out ALL external IP's?
No, that cant be the reason. Why do you think this?
SupportRock
