- Joined
- Oct 19, 2017
- Messages
- 131
- Reaction score
- 23
Is there any plans to repair semi-attended transfers on 3CX phone system?
It is months it does not work in 3CX phone system on fanvil nor grandstream phones. I have decided to try semi-attended transfers on those phones with other PBX systems. It works perfectly on any asterisk based PBX and works with freeswitch too.
The way semi-attended transfers worked for years with 3CX phone system and continue working on other systems is the following. We configure a BLF to work as semi-attended transfer.
There is no way to make this work with 3CX. And it is months it does not work.
To do semi-attended transfer we have to press at least three keys now. Transfer key, BLF, and transfer key again if a blind transfer is needed.
Quite annoying for everyone. I receive complaints constantly about this. Pleople don't want to press so many keys. And that's not the worse. They are used to do it the way I describe and they get really pissed off when it does not work. Besides it not only does not work, if you do it that way the 3CX phone system do all sorts of strange things. Even lossing calls which are no more handle by Extension1 nor by Extension2 and External remains on hold forever till he hangs.
Quite annoying too that the behaviour changes depending if 3CX General setting "Play Busy prompt when extension is busy" is enabled or not.
- External1 calls Extension1
- Extension1 starts transfer by just pressing Extension2 BLF key.
- Automatically External1 gets on hold hearing music on hold and Extension1 starts a new call to Extension2.
- Now Extension1 has two options:
- Waits for Extension2 to answer. Extension2 rings. External continues hearing music on hold. After Extension2 answers the call, Extension1 talks to Extension2 and hangup to finish the transfer.
- Hangup not waiting for Extension2 to answer. Extension1 should be freed from the call. Extension2 continues ringing. External hears ring tone
