Send original CID when making a blind transfer
jazziao
I have been looking all over the web for this but all suggested solutions did not work for me.
I have this:
Agent A receives an external call
Agent A wants to transfer the call to Agent B
when agent A calls B to transfer call, B sees it as an internal call from A
Where do I have to look in order to make Agent B see the original CID and not Agent A on screen?
Been looking for this all over the place and modified all sorts of conf files but to no avail. Please point me in the right direction.
Thanks in advance.
jazziao,
It can depend on a number of factors which includes the phone types and how they do blind transfer.
More info can be obtained here.....
http://www.freepbx.org/forum/freepbx/ge ... meone-else
trustrpid and sendrpid are definitely in the right area.
Regards
Bob
Thanks for your help Bob.
I already tried setting trustrpid and sendrpid to yes in the trunks and features.conf and their custom and additional files but to no luck. I also set blindxfer=1 in features.conf file and realoaded but to no luck. Something I did notice was that value returning to its original value again. Features.conf indicates that this is generated from FreePBX but it does not say where I have to go to make this change.
The link you supplied is great but it gets me to square one since I already tried that. Any painless way to accomplish this?
Worked on this at phones level, had to make a little ajustment to the provisioning files.
yarusemiKK
