Solved Service keeps on going down and disconnecting
Effervescence
Trial User
I have experienced an issue where my web client keeps saying "disconnected...trying to connect" severally.
After an SSH into the PBX I discovered the following service was not running: [email protected] loaded failed failed PostgreSQL Cluster
This has happened severally today and a start of the service alone solves the issue.
KIndly advise on the cause and remedy as I cannot keep on restarting the service forever
It is a 8SC 3CX Pro edition
Hello @Kingpin_Ke
Regarding the [email protected] loaded failed PostgreSQL Cluster error, I would suggest opening a ticket with our Support team so we can investigate and find the solution to this.
Hello @Kingpin_Ke
I was able to discover the issue, It was low storage leading to the system killing the service. Additional resources solved the issue
Isuru Eranga
