Services Stopping - PBXExpress on Azure
coritas
Forum User
Recently created 3cx instance on Azure using pbxepress. Every day or two the following services stop -
"Service stopped…
3CX Service notification
Following service(s) were stopped recently:
3CXPhoneSystemMC01
3CXSystemService01"
I can SSH to the instance and start the services, but how can I find out why they may be stopping?
Hello @coritas
The most often cause for services stopping is lack of resources. Make sure that the instances have enough resources to handle the amount of extensions and the amount of calls you are getting.
If the issue persists i would recommend creating a ticket with our support department so they can look into the issue.
Many thanks I'll bump up the resources and see how it goes
Techmansam
