Services will not start
dwatson-cnhreman
Good day,
We are running 3CX with the trial license. We have ordered a full PRO license but have not received it from our partner yet or I'd submit a proper ticket. I'm using this temporary setup to configure the system and get the project moving.
Late yesterday, I started seeing the web portal down with 403 Forbidden. Digging in, various services are failing to start with the error:
Description: A .NET Core application failed.
Application: 3CXManagementConsole.exe
Path: C:\Program Files\3CX Phone System\Bin\3CXManagementConsole.exe
Message: Error:
An assembly specified in the application dependencies manifest (3CXManagementConsole.deps.json) was not found:
package: 'MongoDB.Libmongocrypt', version: '1.0.0'
path: 'lib/netstandard1.5/MongoDB.Libmongocrypt.dll'
Windows 10, fully updated. 3CX is fully updated. I found a copy of the .dll file and tried to re-register it, but it does not register (not all .dll's can be registered). I searched in Windows Explorer and cannot find a folder called netstandard1.5 to place the .dll file in.
Is there a way to re-install this dll or the mongo drivers? I searched and it looks like it is distributed with the program.
No production down or anything terrible here; just trying to keep our new phone system project progressing.
Thanks,
Dan
It maybe quicker to reinstall
Do you have a backup of the system, if so move the backup to a folder outside of 3cx
uninstall 3cx
reboot system
delete 3cx folders in c:\programdata , c;\program files
reinstall , select restore from backup
If you do not have backup, try dos backup command - https://www.3cx.com/docs/backup-restore-command-line/#h.cw2r6zdqo145 - use full option
Good day,
Message: Error:
Thanks,
Dan
Same thing happens to me last week after last update. The only way to resolve this was doing a fresh reinstall and upload a backup.
Reactions: dwatson-cnhreman
3K8iMGWviZ
