Solved Set participant name with csv import not working
HExSM
Forum User
I read in another post that you can set a participant name, if you import a csv file in the following format:
Code:
Participant Name,[email protected]
But when the participant joins the conference, then still the first part of the email address is used as name.
What am I doing wrong?
This should be correct, can you open your .csv in a plain text editor and confirm the content?
I double checked it in a text editor and the syntax is correct. But no matter which Name I enter, it's always using the name from the email address.
Ok tell me your PBX version as seen on the right side of the dashboard, and also please send me a private message including the Organizer's URL for a test webmeeting.
PBX 16.0.5.612
Windows Client 16.3.0.144
Kindly update your PBX to the latest version, and inform us whether the issue is now resolved.
Software was updated, but it's still not working.
PBX 16.0.7.1078
Windows Client 16.3.0.198
Ok then please create a file like the one you mentioned, and upload it in a public folder.
Send me the link privately so I can check the file.
- Ensure you have tested this file on your side first
- Ensure that the emails contained, are not already added to extensions in your PBX
As per our conversation, this is a limitation of the Windows client.
You can use the Webclient to create meetings with CSV and the names will appear as expected.
Hassan Murasan
