Solved Set to Vibrate Only?
tobinsol
Is it possible to configure the Android app to vibrate only (not ring) for incoming calls, without setting the entire phone to vibrate only? Going into the Android notification settings for the app > Incoming Calls > Sound > None does not work, and when going to the in-app Settings > Advanced > Ringtone Type > Custom > None, it does not keep that setting and instead reverts to whatever it was set to previously.
The solution given in this thread works but only vibrates once per call whereas I am trying to have it vibrate continuously until accepted or rejected.
https://www.3cx.com/community/threads/unable-to-choose-silent-ringtone.114186/#post-528841
got it resolved - no further needs
SDNM
