Unable to choose "Silent" ringtone
ito.Hamish
3CX Android app 18.1.1.55
Samsung Galaxy S20 FE, Android version 12
(also same result on other android phones in the office)
I am trying to have a silent ringtone while still having vibration.
The silent ringtone does not save, it reverts back to whatever ringtone was previously selected.
Selecting Silent from the main menu is not a valid solution because it also disables vibrate
≡ > Settings > Advanced >
Ringtone Type = Custom
Select Ringtone = Silent
When going back, the silent ringtone is not applied,
But using this method and selecting any other ringtone correctly saves the selected tone.
Hi @ito.Hamish
Thanks for your feedback.
Firstly our app does not allow the selection of Custom Silent ringtone since as you correctly stated, we have a dedicated Silent mode for that.
Now my understanding is that you would like to have no ringtone + vibration.
Please follow the steps mentioned here.
- Set your device to Silent Mode [Android App Settings (top left hamburger menu) > Silent Mode > Confirm]
- Android App Settings (top left hamburger menu) > Settings > Advanced > Notifications, audio & visual effects > Vibrate > Notification Categories > Click on Silent mode text (not the switch) > Enable Vibrate (by default this switch is off)
Reactions: ElenaF_3CX
Jeff_MKC
