Solved Setting a starting extension number
AK-47
Trainee Partner
I have 3 digit extensions in my setup and have a convention in place the has exclusions. For exampl the 000-099 range is excluded in the convention. User extensions exist in the 100 range, Digital Reception is in the 700 range, Queue's in the 800 range and Ring Groups in th 900 range.
I also have Office365 integration in place. When a new user is added to the O365 tenancy the extension is always created in the exclusion range. Is there a way to set a default starting number for this (and for the other ranges mentioned above)? I can't seem to find anything documented.
OK ignore this entire thing. I hadn't realised that these functions had been updated to do exactly what I wanted, since the last time I configured a 365 integration.
DOH!
footandankle.my3fcx.us
