pws Free User Joined Sep 9, 2026 Messages 2 Reaction score 0 Sep 14, 2026 #1 I am trying to verify if it is not possible to setup TLS if I am using Flowroute. I have been told they use mTLS which 3cx does not support. If this is the case what suggestions do you have so I can have end-end encryption? Thank you!
bitn2 3CX MVP Platinum Partner Advanced Certified Joined Mar 25, 2020 Messages 2,707 Reaction score 1,608 Sep 21, 2026 #2 Use a supported provider with TLS.
