Solved Setting up for first time but getting error...
erectcredit
Trial User
When i try adding a new trunk after initial log in. i get the following error "undefined: The input was not valid. delta: The delta field is required."
How do i fix that?
Reactions: bu-G
same issue here by creating a new trunk. can figure out what the "delta" field should be?
Did you ever end up solving this issue? If so, what did you do?
Hi, are you getting this now? What version/install type?
I was getting it with post requests in general yesterday, end up getting the creating contacts post to work. Still getting it when creating a new user.
I am only testing in two builds right now
Version 20.0 Update 6 (Build 486 Alpha)
Type Enterprise Annual On Premise
Version 20.0 Update 5 (Build 551 Release)
Perhaps start a new thread in a more visible forum, there might be someone that has resolved this already.
I ended up getting it sorted. Had something to do with how I was packaging the json and it was not parsing it appropriately
Reactions: Saky
LeeonLau
