Setup more than 2 3CX installation in a Single Firewall with one public IP Address
JLMSimao
Good morning Team,
I have one Fortinet firewall with one public IP. I ave one 3CX installed with all 3CX Policies created on firewall.
I need to install two more new 3CX installations and need and firewall policies (https://www.3cx.com/docs/fortigate-firewall-configuration/).
I KNow 3CX default ports for https are 443 and 5001. In this cases how to setup this on my firewall. Should i have one public IP for each 3CX installations. HOw to create policies for many 3CX installation on the same firewall.
I appreciate your help.
Best regards
https://www.3cx.com/community/threads/hosting-more-than-1-3cx-servers-on-the-same-lan.124801/
Quoting Charles
You should not have multiple instances assigned to the same Public IP. This will cause issues with being unable to port forward the required ports to each system individually and end up with problems, such as audio issues, as ports will not be properly forwarded.
You need to have a separate public IP assigned to each instance from which you can open and forward the required ports from the firewall.
You should look at using multi company if you want to do this.
LewisJC
