Solved several trunks matched by DID only.
ITSmartwork
Using didww and the operator told me to configure 2 separate trunks, one for inbound and one for outbound.
It worked until i added the outbound trunk. Now, the problem is that when i call the number, i see on 3CX "several trunks matched by DID only. " but the trunk for inbound is specified to accept it for inbound only and the one for outbound is setup to work on outbound only. The question is: why doesnot 3CX filter by itslef: if a call arrives, then go and filter/search the trunks for inbound only.
thank you
i removed the did number from the trunk and used the "Default Outbound Caller ID". That fixed the issue
SG_F7
