Share your Webinars on your Website with the 3CX Webinars Plugin for WordPress
Webinars will show, webmeetings will not. I see another member posted that this is "correct behavior" for the WP plugin - if someone from 3cx could formally confirm that is accurate. If so, when would WebMeetings be added to show for users and moreover, why won't they show? Many threads exists with users complaining of the same problem - "blank screen" - which is a result of them expecting to see WebMeetings there.
Thanks, took a look. Not sure it relates to my post. I was simply pointing out that webmeetings don't show with the shortcode, only webinars. I have no problem getting Webinars to show and I guess technically getting the plugin to "work", although the issue I have (as do many others) is that the plugin is not designed to show webmeetings - only webinars. thanks
Personally, I only want Webinars to show. Not Web Meetings. If the feature is added to allow meetings I would hope that users can configure which one(s) to show.
Reactions: neville
Some feature requests towards 3CX Webinars from our side:
1) When setting up a new webinar, 3CX forces you to add at least one participant to the webinar. This leads into an occoupied seat and reduces the total number of available seats. With webmeetings it makes sense to force naming at least one participant, but not with webinars.
2) It should be possible to disable the plugin from displaying the total number of seats taken on the WordPress webinar page. For example, if you have 25 seats and only 2 are taken, this could be interpreted by potential attendees as "this webinar is not attractive".
3) Please release a new version that has been tested with the latest version of WordPress (5.4.1) and supports at least PHP-FPM 7.3.18.
Hi! Same problem here. It shows a blank screen but none of the webinars created. Is this extension still up2date? Last modified 11 month ago according to WordPress. I'm using WordPress 5.4.
This one get's even weird when using Elementor Pagebuilder (v2.9.8). This will result in displaying codes, but no content, see screenshot.
Has anyone a solution on this, please? Thanks!
Hello;
The plugin is working, I created a webiner in 3cx after adding it to my web page a few days ago and it instantly appeared on the page.
Some webinars I have created https://www.trakyatelekom.com/webinar.
Good luck with.
Reactions: N_G
jb_erp
