Should I run apt upgrade manually?
coreybrett81
I updated to 16.0.504 this morning using the web admin.
After updating, "apt update & apt list --upgradable" informs me that there are 55 packages that should be updated.
Bash:
root@cbi:~# apt list --upgradable
Listing... Done
base-files/oldstable 9.9+deb9u12 amd64 [upgradable from: 9.9+deb9u9]
curl/oldstable 7.52.1-5+deb9u10 amd64 [upgradable from: 7.52.1-5+deb9u9]
gettext-base/oldstable 0.19.8.1-2+deb9u1 amd64 [upgradable from: 0.19.8.1-2]
grub-common/oldstable 2.02~beta3-5+deb9u2 amd64 [upgradable from: 2.02~beta3-5+deb9u1]
grub-pc/oldstable 2.02~beta3-5+deb9u2 amd64 [upgradable from: 2.02~beta3-5+deb9u1]
grub-pc-bin/oldstable 2.02~beta3-5+deb9u2 amd64 [upgradable from: 2.02~beta3-5+deb9u1]
grub2-common/oldstable 2.02~beta3-5+deb9u2 amd64 [upgradable from: 2.02~beta3-5+deb9u1]
libcomerr2/oldstable,oldstable 1.43.4-2+deb9u1 amd64 [upgradable from: 1.43.4-2]
libcurl3/oldstable 7.52.1-5+deb9u10 amd64 [upgradable from: 7.52.1-5+deb9u9]
libexif12/oldstable 0.6.21-2+deb9u1 amd64 [upgradable from: 0.6.21-2+b2]
libexpat1/oldstable,oldstable 2.2.0-2+deb9u3 amd64 [upgradable from: 2.2.0-2+deb9u2]
libfreetype6/oldstable 2.6.3-3.2+deb9u1 amd64 [upgradable from: 2.6.3-3.2]
libfribidi0/oldstable 0.19.7-1+deb9u1 amd64 [upgradable from: 0.19.7-1+b1]
libgd3/oldstable 2.2.4-2+deb9u5 amd64 [upgradable from: 2.2.4-2+deb9u4]
libglib2.0-0/oldstable 2.50.3-2+deb9u2 amd64 [upgradable from: 2.50.3-2]
libglib2.0-data/oldstable 2.50.3-2+deb9u2 all [upgradable from: 2.50.3-2]
libicu57/oldstable 57.1-6+deb9u3 amd64 [upgradable from: 57.1-6+deb9u2]
libidn11/oldstable 1.33-1+deb9u1 amd64 [upgradable from: 1.33-1]
libldap-2.4-2/oldstable 2.4.44+dfsg-5+deb9u3 amd64 [upgradable from: 2.4.44+dfsg-5+deb9u2]
libldap-common/oldstable 2.4.44+dfsg-5+deb9u3 all [upgradable from: 2.4.44+dfsg-5+deb9u2]
libmariadbclient18/oldstable 10.1.44-0+deb9u1 amd64 [upgradable from: 10.1.38-0+deb9u1]
libpam-systemd/oldstable 232-25+deb9u12 amd64 [upgradable from: 232-25+deb9u11]
libperl5.24/oldstable 5.24.1-3+deb9u6 amd64 [upgradable from: 5.24.1-3+deb9u5]
libpq5/oldstable 9.6.17-0+deb9u1 amd64 [upgradable from: 9.6.15-0+deb9u1]
libsasl2-2/oldstable,oldstable 2.1.27~101-g0780600+dfsg-3+deb9u1 amd64 [upgradable from: 2.1.27~101-g0780600+dfsg-3]
libsasl2-modules-db/oldstable,oldstable 2.1.27~101-g0780600+dfsg-3+deb9u1 amd64 [upgradable from: 2.1.27~101-g0780600+dfsg-3]
libssl1.0.2/oldstable,oldstable 1.0.2u-1~deb9u1 amd64 [upgradable from: 1.0.2s-1~deb9u1]
libssl1.1/oldstable,oldstable 1.1.0l-1~deb9u1 amd64 [upgradable from: 1.1.0k-1~deb9u1]
libsystemd0/oldstable 232-25+deb9u12 amd64 [upgradable from: 232-25+deb9u11]
libudev1/oldstable 232-25+deb9u12 amd64 [upgradable from: 232-25+deb9u11]
libxslt1.1/oldstable 1.1.29-2.1+deb9u2 amd64 [upgradable from: 1.1.29-2.1]
linux-image-amd64/oldstable 4.9+80+deb9u10 amd64 [upgradable from: 4.9+80+deb9u7]
openssh-client/oldstable 1:7.4p1-10+deb9u7 amd64 [upgradable from: 1:7.4p1-10+deb9u6]
openssh-server/oldstable 1:7.4p1-10+deb9u7 amd64 [upgradable from: 1:7.4p1-10+deb9u6]
openssh-sftp-server/oldstable 1:7.4p1-10+deb9u7 amd64 [upgradable from: 1:7.4p1-10+deb9u6]
openssl/oldstable,oldstable 1.1.0l-1~deb9u1 amd64 [upgradable from: 1.1.0k-1~deb9u1]
perl/oldstable 5.24.1-3+deb9u6 amd64 [upgradable from: 5.24.1-3+deb9u5]
perl-base/oldstable 5.24.1-3+deb9u6 amd64 [upgradable from: 5.24.1-3+deb9u5]
perl-modules-5.24/oldstable 5.24.1-3+deb9u6 all [upgradable from: 5.24.1-3+deb9u5]
postgresql/oldstable,oldstable 9.6+181+deb9u3 all [upgradable from: 9.6+181+deb9u2]
postgresql-9.6/oldstable 9.6.17-0+deb9u1 amd64 [upgradable from: 9.6.15-0+deb9u1]
postgresql-client-9.6/oldstable 9.6.17-0+deb9u1 amd64 [upgradable from: 9.6.15-0+deb9u1]
postgresql-client-common/oldstable,oldstable 181+deb9u3 all [upgradable from: 181+deb9u2]
postgresql-common/oldstable,oldstable 181+deb9u3 all [upgradable from: 181+deb9u2]
postgresql-contrib-9.6/oldstable 9.6.17-0+deb9u1 amd64 [upgradable from: 9.6.15-0+deb9u1]
python-apt-common/oldstable,oldstable 1.4.1 all [upgradable from: 1.4.0~beta3]
python3-apt/oldstable,oldstable 1.4.1 amd64 [upgradable from: 1.4.0~beta3]
python3-reportbug/oldstable 7.1.7+deb9u3 all [upgradable from: 7.1.7+deb9u2]
sudo/oldstable,oldstable 1.8.19p1-2.1+deb9u2 amd64 [upgradable from: 1.8.19p1-2.1]
systemd-sysv/oldstable 232-25+deb9u12 amd64 [upgradable from: 232-25+deb9u11]
tcpdump/oldstable,oldstable 4.9.3-1~deb9u1 amd64 [upgradable from: 4.9.2-1~deb9u1]
tzdata/oldstable,oldstable-updates 2019c-0+deb9u1 all [upgradable from: 2019b-0+deb9u1]
udev/oldstable 232-25+deb9u12 amd64 [upgradable from: 232-25+deb9u11]
Should I do this?
The server was setup about a year ago using the instruction from 3CX for apt installs.
No.
3CX takes care of installing the necessary updates and security fix. Running this yourself might cause incompatibilities between softwares. For example with the PostgreSQL database.
Reactions: AWS2P
