sim calls
franzstuebi
SMB User
How many simultaneous calls does "Startup" and "Startup Pro" licenses have?
Pretty sure it's unlimited as it is based for users in this case. StartUP is up to 10, Pro is up to 25 I believe.
Reactions: Charles_3CX
As mentioned yes, it’s unlimited on the 3cx side, but you will be restricted by the amount of external calls from the VoIP providers side, this you will need to check from the chosen provider.
Thanxx a lot for the information.
Edvard
