SIP Accounts
MPH2020
Forum User
After the latest Firmware upgrade on GXP2160 & GXP6125 the phones shows two SIP accounts are there .
If we login to the phone GUI then we can see only one accounts registered .
Any solution for this ?
The screenshot info is correct, for the reason posted by cobaltit.
3cx requires two line keys with the same ext number to work correctly.
Before version 15 it was only one account showing after ver 16 released and after the upgrade it now showing two accounts .
So it is not an bug . It is way the 3cx works
Correct. Per Grandstream's recommendation on how to work best with 3CX it requires 2 line keys. This was changed in the template so when you upgraded it changed the phones to comply with the latest template. Not a bug but working as intended.
Thank you for the support
3K8iMGWviZ
