Sip alg failed with Mikrotik
Shadi Bamalhs
I disabled sip alg from mikrotik router but my sip alg status stll failed :
  • resolving 'stun-eu.3cx.com'... done
  • resolving 'stun2.3cx.com'... done
  • resolving 'stun3.3cx.com'... done
  • resolving 'sip-alg-detector.3cx.com'... done
  • testing 3CX SIP Server... failed (How to resolve?)
    • stopping service... done
    • detecting SIP ALG... failed (How to resolve?)
    • testing port 5060... done
    • starting service... done
  • testing 3CX Tunneling Proxy... done
    • testing port 5090... done
Can any one help, i went throw all threads and i am trying to solve this issue more than one week.
here is my mikrotik setting :
Code:
[admin@MikroTik] > ip firewall filter print
Flags: X - disabled, I - invalid, D - dynamic
 0 X  chain=input action=drop protocol=udp in-interface=ether1 dst-port=53 log=no log-prefix=""
 1 X  chain=input action=drop protocol=tcp in-interface=ether1 dst-port=53 log=no log-prefix=""
 2 X  chain=input action=accept connection-state=established log=no log-prefix=""
 3 X  chain=input action=accept connection-state=related log=no log-prefix=""
 4 X  chain=forward action=accept connection-state=established log=no log-prefix=""
 5 X  chain=forward action=accept connection-state=related log=no log-prefix=""
 6 X  chain=forward action=drop connection-state=invalid log=no log-prefix=""
 7 X  chain=input action=drop in-interface=ether1 log=no log-prefix=""
 8 X  chain=input action=accept connection-state=established log=no log-prefix=""
 9 X  chain=input action=accept connection-state=related log=no log-prefix=""
10 X  chain=forward action=accept connection-state=established log=no log-prefix=""
11 X  chain=forward action=accept connection-state=related log=no log-prefix=""
12    chain=input action=accept connection-state=established
13    chain=input action=accept connection-state=related
14    chain=forward action=accept connection-state=established
15    chain=forward action=accept connection-state=related
16    chain=forward action=drop connection-state=invalid
17    chain=input action=drop in-interface=ether2 log=no log-prefix=""
[admin@MikroTik] > ip firewall nat print
 0    chain=srcnat action=masquerade out-interface=ether1 log=no log-prefix=""
 1    chain=dstnat action=dst-nat to-addresses=172.16.16.172 to-ports=5001 protocol=tcp in-interface=ether1 dst-port=5001 log=no log-prefix=""
 2    chain=dstnat action=dst-nat to-addresses=172.16.16.172 to-ports=9000-10999 protocol=udp in-interface=ether1 dst-port=9000-10999 log=no log-prefix=""
 3 X  chain=dstnat action=dst-nat to-addresses=172.16.16.134 to-ports=9000-9500 protocol=tcp in-interface=ether1 dst-port=9000-9500 log=no log-prefix=""
 4    chain=dstnat action=dst-nat to-addresses=172.16.16.172 to-ports=5060 protocol=udp in-interface=ether1 dst-port=5060 log=no log-prefix=""
 5    chain=dstnat action=dst-nat to-addresses=172.16.16.172 to-ports=5060 protocol=tcp in-interface=ether1 dst-port=5060 log=no log-prefix=""
 6    chain=dstnat action=dst-nat to-addresses=172.16.16.172 to-ports=4443 protocol=tcp in-interface=ether1 dst-port=4443 log=no log-prefix=""
 7    chain=srcnat action=masquerade src-address=192.168.60.0/24 out-interface=ether1 log=no log-prefix=""
 8 X  chain=dstnat action=dst-nat to-addresses=172.16.16.134 to-ports=9000-9099 protocol=udp in-interface=ether1 dst-port=9000-9099 log=no log-prefix=""
 9    chain=dstnat action=dst-nat to-addresses=172.16.16.172 to-ports=443 protocol=tcp in-interface=ether1 dst-port=443 log=no log-prefix=""
10 X  chain=dstnat action=dst-nat to-addresses=172.16.16.134 protocol=tcp in-interface=ether1
11 X  chain=dstnat action=dst-nat to-addresses=172.16.16.134 protocol=udp in-interface=ether1
12 X  chain=dstnat action=dst-nat to-addresses=172.16.16.134 to-ports=5000 protocol=tcp in-interface=ether1 dst-port=5000 log=no log-prefix=""
13 X  chain=dstnat action=dst-nat to-addresses=172.16.16.134 to-ports=5060 protocol=udp in-interface=ether1 dst-port=5060 log=no log-prefix=""
14    chain=dstnat action=dst-nat to-addresses=172.16.16.172 to-ports=48000-65535 protocol=udp in-interface=ether1 dst-port=48000-65535 log=no log-prefix=""
15    chain=dstnat action=dst-nat to-addresses=172.16.16.172 to-ports=5090 protocol=tcp in-interface=ether1 dst-port=5090 log=no log-prefix=""
16    chain=dstnat action=dst-nat to-addresses=172.16.16.172 to-ports=5061 protocol=tcp in-interface=ether1 dst-port=5061 log=no log-prefix=""
17    chain=dstnat action=dst-nat to-addresses=172.16.16.172 to-ports=5090 protocol=udp in-interface=ether1 dst-port=5090 log=no log-prefix=""
18 X  chain=srcnat action=masquerade out-interface=ether1 log=no log-prefix=""
19 X  chain=srcnat action=masquerade out-interface=ether1 log=no log-prefix=""
20 X  chain=srcnat action=masquerade out-interface=ether2 log=no log-prefix=""
Please disable Service Port 5060 and try again.
Code:
/ip firewall service-port
set sip disabled=yes ports=5060
Code:
its disabled with same way
https://www.dropbox.com/s/zgcb3hrr17skgkd/mikrotik.JPG?dl=0
Please make sure to use the default Firewall Filter settings of the MikroTik.
I use next Firewall NAT settings to connect Internet to PBX.
Code:
 0    ;;; defconf: masquerade
      chain=srcnat action=masquerade out-interface-list=ether1 log=no log-prefix="" ipsec-policy=out,none
 1    chain=dstnat action=dst-nat to-addresses=172.16.16.172 protocol=tcp in-interface-list=ether1 dst-port=5060,5061 log=no log-prefix=""
 2    chain=dstnat action=dst-nat to-addresses=172.16.16.172 protocol=udp in-interface-list=ether1 dst-port=5060 log=no log-prefix=">>>>"
 3    chain=dstnat action=dst-nat to-addresses=172.16.16.172 protocol=udp in-interface-list=ether1 dst-port=9000-10999 log=no log-prefix=""
 4    chain=dstnat action=dst-nat to-addresses=172.16.16.172 protocol=tcp in-interface-list=ether1 dst-port=5090 log=no log-prefix=""
 5    chain=dstnat action=dst-nat to-addresses=172.16.16.172 protocol=udp in-interface-list=ether1 dst-port=5090 log=no log-prefix=""
 6    chain=dstnat action=dst-nat to-addresses=172.16.16.172 protocol=tcp in-interface-list=ether1 dst-port=5001 log=no log-prefix=""
do you think this is my issue ? how to config that?
I have make a mistake when I was editing the list… Sorry.
“out-interface-list=” should be “out-interface=” and “in-interface-list=” should be “in-interface=”
Do You mean this "ipsec-policy=out,none" should be "in" ?
No.
Just out-interface without "-list" and in-interface without "-list", nothing else.
Code:
/ip firewall nat
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none out-interface=ether1
add action=dst-nat chain=dstnat dst-port=5060,5061 in-interface=ether1 protocol=tcp to-addresses=172.16.16.172
add action=dst-nat chain=dstnat dst-port=5060 in-interface=ether1 protocol=udp to-addresses=172.16.16.172
add action=dst-nat chain=dstnat dst-port=9000-10999 in-interface=ether1 protocol=udp to-addresses=172.16.16.172
add action=dst-nat chain=dstnat dst-port=5090 in-interface=ether1 protocol=tcp to-addresses=172.16.16.172
add action=dst-nat chain=dstnat dst-port=5090 in-interface=ether1 protocol=udp to-addresses=172.16.16.172
add action=dst-nat chain=dstnat dst-port=5001 in-interface=ether1 protocol=tcp to-addresses=172.16.16.172
ok , but still the Sip-alg status failed
Probably it will not do of any help, but please reboot router and 3CX server and test again.
I reboot it ,, same issue , even port 9000 not working
Just re-read your initial post again, but why are you select ether2 instead of ether1 in
I tried both bot still same issue
ether1 Internet
ether2 LAN
Zexus
