Solved Sip errors please explain
ultimatepie
New User
SIP request (REGISTER) from ***.***.***.*** was rejected. Reason: Block WAN requests is ON. Message: REGISTER sip: ***.***.***.*** SIP/2.0 Via: SIP/2.0/UDP
Go to your extension settings and then go to Options and make sure "disallow use of extension outside of LAN" is off.
and also "block remote..."
Reactions: YiannisH_3CX
Legend thank you
can you set this as a default, or is it set on a user bases
It's defaulted to block STUN
Cloudstar
