Solved SIP ID Not Working After Upgrade
Rhys Haskell
I have upgraded a few instances to V16 and I have noticed that SIP ID has stopped working. We use this to dial 0 for reception, the call just says not found. Does anybody know a fix for this?
In my case this was because the Network Settings -> FQDN -> Allow calls from/to external SIP URIs was not checked.
Reactions: gmal.co.uk
I'm on v15.5 with that unchecked and SIP ID works fine. My server is on the same subnet as the handsets.
Mark is correct. For version 16, you have to enable this. Its a known issue.
It is a corrected issue that SIP-ID was working in v15.X even URI dialing was not enabled...
Thanks for your help this issue is now resolved.
Reactions: YiannisH_3CX
GP Concepts
