SIP multiple outbound trunks
nicoonline
SOHO User
Is there a solution when having two trunks (NO Registration) to go to the second trunk when the first is failing.
Today there is a 32 seconds delay. That is not possible in a business environnement.
You said that you cannot detected the trunk down, that is not true. You can send SIP Option every 60 seconds and in case of no answers , you can set the trunk down.
You can also put a timer of 2000ms. If you didn't receive a trying, cancel the call and go to the next.
I worked with a lot of brands and this is the first time i saw this.
