SIP SIMPLE Support
alexcc2000
Hello
Just started my 3CX journey... trying to use it with Acrobits cloudsoftphone application?
does anyone know if 3CX it supports SIM SIMPLE messaging and how it can be enabled?
Thank ytou
Simple answer - no
why are you using Acrobits , have you looked at 3cx applications - 3cx web, windows and mobile
Thanks Saqqara - the reason is that Acrobits is providing a whitelabeled application that you can also add additional logic for credit/et al
Reactions: craigreilly
the way I see it Acrobits cloudsoftphon is a softphone application with credit for calls, etc, that connects to the internet.
3cx is a pabc system, where you configuring incoming trunks, and have handsets, softphore application connect to it which is totally different
3K8iMGWviZ
