SIP TRUNK DE-REGISTERS AND COMES UP AGAIN AFTER EXACTLY 5 Minutes
Effervescence
Trial User
I have a 4SC 3CX Pro edition. The SIP trunk keeps on de-registering and registers again after exactly 5 minutes. The issue has been occuring severally and frequently for some time. The 3CX is version 20. From the logs on 3CX Log reader I see that after failing when it tries re-registering it gets the error 403 Forbidden. Note that any time it deregisters it comes up after exactly 5 minutes. What could be causing this to happen? What is the remedy?
Hi there.
If it's not a networking issue where the Phonesystem can contact the provider, did you try to see from the provider end what the issue there and what the cause is?
Hi there.
It's not a networking issue. I will contact the provider to know the cause.
Sure, let us know how it goes.
Error 403 Forbidden indicates problems with authorization when trying to register a SIP trunk. Possible causes may include incorrect credentials, incorrect security settings, or network restrictions. Check your SIP trunk credentials and make sure they are up to date. Also check your security settings and possible network restrictions that may be blocking registration.
Reactions: OlegR_3CX
Finatra.us
