SIP trunk is not required for local IPphone-to-IPphone "intercom" function, is it?
chastate
New User
Hi. First exposure to 3CX, trying to check it out. I want to initially configure just 2 telephone sets. The IP phones are SIP phones. They will initially only be used for making "intercom" calls to each other.
The 3CX documentation states that "You must use a supported, register based SIP trunk." Am I correct that SIP trunk(s) are only required if you want to make telephone calls via the PSTN?
Thank you!!
That is correct
Thank you, Sir Cobalt!
Isaac415
