- Joined
- Feb 14, 2022
- Messages
- 2
- Reaction score
- 1
Hi All,
I have a strange one here. I have a SIP trunk setup in the 3cx system which is "internode". I know this is not supported so "Generic" is used as the service.
I am able to add the trunk successfully and it all works and stays online until it comes time to "re-authenticate". When this occurs the trunk errors advising that "Registration at INTERNODE SIP TRUNK has failed. Destination (sip:203.2.134.1:5060;transport=TCP;lr) is not reachable, DNS error resolving FQDN, or service is not available.".
I have checked with Internode and they confirm they can see us sending them registration requests with auth (w/auth) however when the issue occurs they are sending us a register packet with out auth which is fine but as it has no auth details we will reject it with a 401 unauthorised and so the customer should then resend the register packet but this time with auth (w/auth) but the customer does not do this so the registration does not renew and the trunk becomes unregistered when the expiry timer on the last good registration expires.
Has anyone seen or know if there is a setting that i can change to fix this?
NOTE: i have tried UDP as well for communication with the exact same issue. I have confirmed that the settings are all correct and i have reviewed the firewall mutltiple times looking at Flood protection and other items mentioned in the forums and it looks fine.
Any suggestions would help
Thanks in advanced,
Joe
Thanks in advanced,
Joe
