- Joined
- Aug 25, 2022
- Messages
- 5
- Reaction score
- 0
IM TRY TO CONNECT VOXBEAM AS MY OUTBOUND I HAVE TRY SETTING FROM THE FORUMS , WHEN DIAL I GET THE MSG IN LOGS
UPON CONTACTING THE PROVIDER I GOT THIS RESPONSE PLEASE ADVISE WHAT IAM MISSING
Dear Customer,
Our requirements are that you provide a Genuine number in both your From: & your P-Asserted-Identity: headers in +E164 format, currently you are sending your From: header as sip:[email protected] this might be a National format in your country but it is unacceptable for us. You are also NOT providing any P-Asserted-Identity: header which again is unacceptable.
Please fix both of these errors before attempting your calls again.""
| 05/18/2023 9:56:15 PM - Call to T:Line:10001>>923182991538@[Dev:sip:[email protected]] from L:71.1[Extn:100] failed, cause: Cause: 403 Forbidden/INVITE from 108.59.2.133:5060 |
| 05/18/2023 9:56:15 PM - [CM503003]: Call(C:71): Call to <sip:[email protected]:0> has failed; Cause: 403 Forbidden/INVITE from 108.59.2.133:5060 |
| 05/18/2023 9:55:58 PM - Call to T:Line:10001>>923182991538@[Dev:sip:[email protected]] from L:70.1[Extn:100] failed, cause: Cause: 403 Forbidden/INVITE from 108.59.2.133:5060 |
| 05/18/2023 9:55:58 PM - [CM503003]: Call(C:70): Call to <sip:[email protected]:0> has failed; Cause: 403 Forbidden/INVITE from 108.59.2.133:5060 |
| 05/18/2023 9:53:52 PM - Call to T:Line:10001>>923182991538@[Dev:sip:[email protected]] from L:69.1[Extn:100] failed, cause: Cause: 403 Forbidden/INVITE from 108.59.2.133:5060 |
| 05/18/2023 9:53:52 PM - [CM503003]: Call(C:69): Call to <sip:[email protected]:0> has failed; Cause: 403 Forbidden/INVITE from 108.59.2.133:5060 |
| 05/18/2023 9:51:35 PM - Call to T:Line:10001>>923182991538@[Dev:sip:[email protected]] from L:68.1[Extn:100] failed, cause: Cause: 403 Forbidden/INVITE from 108.59.2.133:5060 |
| 05/18/2023 9:51:35 PM - [CM503003]: Call(C:68): Call to <sip:[email protected]:0> has failed; Cause: 403 Forbidden/INVITE from 108.59.2.133:5060 |
Dear Customer,
