SIP.US trunk problems with Outbound Rules
Infinitysl
Hi, I need help. I have a problem with outgoing calls through the trunk of SIP.US incoming calls is working but outgoing stay for 2-3 seconds on dialing mode and after disappears
The error that is repeated through most of that log is ..
10/23/2020 9:05:11 PM - Leg L:8436.3[Line:10008>>ELECTED_PHONE] is terminated: Cause: 404 Not Found/INVITE from OPERATOR_IP_ADDRESS:5060
So...it appears you are sending a number, it is reaching your provider, and your provider is responding with a 404 message. Because you have removed the numbers, I have no idea in what format they are being sent, but, it is probably something that your provider does not like.
Do any outbound calls work?
I would check with your provider to confirm what format they want to see. If you think that the didits you are sending are correct, then contact them, ask them to look at a call attempt, and then tell you what is not right.
I wrote to the provider SIP.US with attaching a log and they solved the problem thanks for the help.
Now everything works :)
hughesdouglas
