Solved Skill Based Routing change time
Tyler.Calhoun
Trial User
Hi all,
We are using the Skill-Based Routing assignment method in our queues - signal all.
This works fine so far. When a call comes in, only the extensions with Skill 1 ring at first.
But my problem is the timesettings.
I want to make sure that the extensions with Skill 2 are only switched on when the Skill 1 extensions are not available.
I have configured the ring Time to 1800 sec. and destination if no answer also to 1800 sec.
Our problem now is that the extensions with Skill 2 will also ring after about 15 - 20 seconds. How can I change this?
Hi @Tyler.Calhoun,
This is not how a Skill Based Routing Ring All strategy should work. It should poll the agents with Skill 1 over and over unless they are on a call / logged out of the queue.
Reactions: Tyler.Calhoun
I deleted the queue and created it again.
Now it seems to work.
Thank you :cool:
Reactions: VasilisV_3CX
Great to hear! Quite an oddity. If you need anything else feel free to open a new thread!
Bluebox Global
