Skip 3CX post-install interface /restore 3CX
dcorazon
Hope you're all doing well. I have 2 questions:
The first question is that I just installed the 3CX IPBX and I need to change the IP adress of that virtual machine before finalizing the install. I was wondering if it's possible to skip the first windows (where it ask you to tun the tool on Using Web browser or from command line).
The second question, what's is included in 3CX backup? is the VM Ip adresse included? The main concern is can i restore a 3CX backup on another server wich already runs 3cx server (i don't need the second server anymore).
To explain the context, I have a 3cx server installed on my OVH public cloud. I need to restore a backup of another 3CX server (i have the backup file). If i clone the existing backup server the change the IPs (public and private) of the clone, can i juste upload the backup file i had from the seond server on the clone and just restored it? will i face some problems using a clone
PS: I can't use 3CX iso because on public cloud you can't use youre own iso and OVH doesn't have 3CX iso on their market place
First question ;
Choose option 1.
You will then have access to make your modifications.
Once finish, restart the wizard like this.
Bash:
sudo /usr/sbin/3CXWizard --cleanup
Second question
No, backups do not include network configurations.
If you use the 3CX FQDN, and you use the same key, the 3CX FQDN will automatically be updated to the new public IP.
First question ;
Thanks for the answers. Did'nt understand your response to my first question (maybe it was cut when posting it ?)
What should i do before having access?
Indeed, there was a sentence missing, it's now corrected. ↑
Reactions: dcorazon
Thanks. have a good day
lastshadow
