SMB server location
pjng1
I created an SMB trial for a customer and spent some time configuring the PBX ready for demo and deployment tomorrow. However, I discovered that the server is in a completely different geographical area. The country must have been selected incorrectly. So my question is - can this be changed post-deployment or do I have to start from scratch?
Backup, start over then restore?
This cannot be changed post deployment. You will have to start over again.
If there's a method to backup SMB/Startup Pro would you be able to share it?
I don't do any SMB, if you can't find a backup, there probably isn't one.
Are you having latency issues? I would stick with what you have and if the trial is a success & they sign a contract, then redo everything.
Just my $0.02
Just note that a different server will have a different 3cx.cloud number.
Yeah I realise. Deleting and reprovisioning is a pretty quick process in all, I should have just done it instead of bellyaching. The lack of a backup just encourages us to document settings thoroughly, but it would be nice.
3CX backs up those servers. SMB is basically one department on a shared server so the whole server is backed up at once.
SupportRock
