SMS Reports
tphoneman
Is there any way or any plans to support SMS reported when not used in a Queue scenario?
I have a client that uses SMS for 1-to-1 communication with their clients. So we have no need to setup/use queues. However, it appears that all reporting for SMS is only when used on conjunction with a queue. My client is looking for a report that would be similar to the extension call report, but for SMS.
Thanks,
Tom
Actually, if I am correct, the CRM integration should still find the contact for a direct conversation, and show the CRM button. If it does, then the SMS reporting should also work.
@edossantos
Unfortunately, we are not using a CRM. Our setup is quite simple. We have a bank of DID numbers that are SMS enabled and just assign a DID to each user.
Then you cannot use the SMS reporting.
You can use the "reports" but those SHOULD show the data even without usage of a queue.
mbar
