Snom D717 no logo
Kyle Sayer
We have a fresh 3CX Server (Enterprise), and Snom D717s.
But, the logo is not appearing on the phones. FW: 10.1.46.16
The logo is set in Custom Background Image, and the colours are set to 0 on alpha.
The logo can also be accessed via a browser. Unsure what else to check, can anyone help?
Have you reprovisioned the phones?
If you go on a phones GUI can you see it has been applied?
Phones have been re-provisioned and factory reset with no difference.
On web interface, I can see the URL of the image and is reachable.
Background colours are also set to 0 opacity/alpha
Does your image meet the criteria:
Logo Properties: Format=.png, width=320, height=240, bitdepth=24
Yep, the phones don't even load the default 3CX logo
Are you able to go back a FW version and see what happens?
you can find the previous FW by browsing your 3CX server 3cxpbx/instance1/data/http/interface/provisioning/<ID>/firmware or firmware_new/snom
Is your PBX local or cloud?
What version?
What is your network toplogy?
Will give that a go and let you know :)
Also:
Cloud based, currently on Direct Stun for testing but will be SBC.
Version: 16 Update 4
Network: Hosted in AWS/Azure, only SBC/Direct connections
I reverted to 10.1.39.11 manually, and the logo appeared.
It disappears when updating to 10.1.42.14, assume this is a bug in the firmware? Or possible out dated template on 3cx?
3K8iMGWviZ
