Snom M200SC provisioning instructions
Rick m Fry
Does anyone have any provisioning instructions for the SNOM M200SC I can find the M300. To run on V15
Thanks in advance apologies if its already covered I did search but found no documents
Hello @Rick m Fry
Please note that there are no provisioning instructions for this model as it is not supported. The Snom supported DECT bases are the M300 and M700. You will probably need to manually configure it to get it working with 3CX or get a supported device that can be provisioned by 3CX.
Call_Flow.co.uk
