Snom M70 internal directory
Dje_dfm
Titanium Partner
Hello
I have a SNOM M900 with two M70
Should the internal directory be added manually?
Thx
If you provisioned the device via 3CX, then we automatically provision the Contacts like we do for all phones.
Your Contacts do need to have an entry in the Mobile field though, otherwise they will not appear.
Thank you for your reply.
I'm talking about internal contacts
ex: call from extension 100 to 102
There is no BLF on these phones.
All your internal extensions will also appear on the M900 except in the case where you:
- have extensions where you clicked their Options > Hide this extension from 3CX company phonebook and 3CX Apps
- have a M900 on a 3CX StartUP system (there is no contacts provisioning on StartUP)
Finatra.us
