Softphone 20.0.460.0 - Not Registered
uhpadmin
I am doing some testing on the latest version and have the softphone installed on my windows machine.
I am able to login, but it is not showing as registered.
We use a mix of Chrome and Edge.
Is there an easy way to fix this?
Fixing on a per install basis is not an option.
OK. Thank you for the pointers.
I figured out I can add to Chrome GPO and it works fine.
Or at least initial results look good.
I will do more testing tomorrow.
Thank you for the feedback.
Let us know the outcome.
Bluebox Global
