SOLVED! preparing a Linksys 942 for external extension
jsadan
Question: I am trying to get a Linksys SPA942 registered as an external extension. What settings on the phone do I need to change? appreciate any help. Will update tomorrow
Answer:
Step 1: Make sure your firewall settings on your system/router are open.
My settings for my router:
Firewall:
SPI (Stateful Packet Inspection) - Disabled
Port forwarding: (Found these ports in 3CX wiki)
SIP TCP/5060-5060 -> Local IP of 3CX machine
SIP TCP/5090-5090 -> Local IP of 3CX machine
SIP UDP/5060-5060 -> Local IP of 3CX machine
RTP UDP/9000-9049 -> Local IP of 3CX machine
Step 2: The SPAXXX phone
From a factory reset (DHCP enabled) these are the changes I made.
SIP Tab:
SIP Parameters:
SIP TCP Port Max: 5090 (changed from 5080)
RTP Parameters:
RTP Packet Size: 0.020 (Was recommended in 3CX video)
Symmetric RTP: Yes (This was the setting that made this a living nightmare for me)
NAT Support Parameters:
STUN Enable: Yes
STUN Server: stun.3cx.com
Ext 1 Tab:
NAT Settings:
NAT Mapping Enable: Yes
NAT keep Alive Enable: Yes
Proxy and Registration:
Proxy: 99.14.10.xxx (Public IP of 3CX machine)
Register Expires: 300
Subscriber Information:
Display Name: External Extension
User ID: 19
Password: (password setup for this extension)
Special Thanks!
To:
KerryG - Thank you for your reply, this isn't the first post you've helped me with.
leejor - Thanks for having the patience and helping me step by step in this process. You are very active on the forums and I am sure we all appreciate your time and knowledge!
Re: preparing a Linksys 942 for external extension
jsadan said:
RTP Port Min: 9000 RTP Port Max: 9003
You might try setting the number a bit higher, 9050. I think 3CX uses two for watch call but I'm not sure it they all start at 9000 and work up. Could a firewall/router be blocking packets?
Dont think so. I see the RTP packets in wireshark but it says it doesnt go through. I allowed RTP ports tcp/udp 9000-50000 and sip tcp/udp ports 5000-10000
Im not sure why the middle address is blank in the last error.
Now I see in the logs a ACK not received error
Wireshark code
Source:192.168.10.202 Destination: 99.145.242.5 Protocol: SIP Info: Status: 407 Proxy Authentication Required (0 bindings)
The PBX machine is asking for authentication to the phone. I am not sure why since it shows up as registered
Symmetric RTP wasnt set to yes in the RTP Parameters... that was all
Edited the first post with Answer and Special thanks
For an external handset I would always use the outbound proxy setting and enable PBX delivers audio for the extension as well - this works much better for two-way audio on remote handsets, whether they're Linksys, Cisco, Yealing or Snom...
If you ever experiencing a one-way audio issue this is one of the most likely suspects...
DenisK
