Solved Some International calls prompt for PIN
Foiler
Call attempts to Jordan (country code 962) get a please enter your password prompt ..
.. even though we have ENABLED calls to Jordan under Security-AllowedCountryCodes AND we have NOT enabled Pin Protect under Extension-Options
Other countries can be dialed without problem.
And you are certain that this is a 3CX recording? Have you checked the 3CX Activity Log comparing a working call, to one asking for a PIN?
Reactions: JohnS_3CX
Thank you and yes I agree this is most likely a problem with our Trunk provider. Will enquire with them and advise back soon.
Update .. yes this was a setting with our Trunk provider where a box was ticked to "block expensive overseas calls" .. many thanks for sending me in the right direction @leejor.
devo.it
