- Joined
- Jun 20, 2018
- Messages
- 4,477
- Reaction score
- 2,191
This is a weird one and I'm not sure what to do with it. It's in our own office. We have three people using the web client/Chrome extension, and one isn't. Of the three, only two have this problem. All have Sennheiser headsets, none have phones. Problem occurs with headset integration in the web client settings set to Sennheiser, and happens using both the Chrome extension and web client (with extension disabled).
- internal or external call comes to our "main" digital receptionist ext 800
- user clicks button in Chrome plugin to answer
- plugin shows the call is answered
- caller thinks call is answered, hears nothing
- user still hears ringing tone/chime in headset as if they haven't answered
- if user then presses headset button, error shows similar to "can't answer call in state 9" (I'm assuming that means "you already answered it")
We have two workarounds:
1) set headset integration to None, and answer call with web client or extension
2) set headset integration to Sennheiser, and answer call with headset button
The digital receptionist sends calls to a ring group. If we call the ring group extension directly, this problem does not happen. If we call the user's extension, this problem does not happen. And to recap the third user (me) does not have this problem.
We didn't have this issue with the Windows client. All three of us switched to using the web client relatively recently. One had been using it for a couple weeks, but didn't have Sennheiser HeadSetup Pro installed so wasn't using the integration and thus didn't notice the issue.
We have restarted the 3CX services and the 3CX server. 3CX version 16.0.4.493. I created a new digital receptionist that forwards immediately to a new ring group (with one extension in it), and don't have this issue with it.
Ideas? Obviously can recreate the main auto attendant but it seems odd that we can only reproduce on some extensions.
