Something other than csf that works
Amphibian
Hey Team,
Are there any substitutes that are similar to csf that work with dyndns names? Since I updated Elastix and csf a year ago I have not been able to get the dyndns portion of csf working and I have expired all possibilities with seeking answers to the issue on their forum as they have either blocked me or not allowing my post to be displayed so if that is the way they desire to operate their forum and not provide assistance I now consider their software about as worthless as can be right now. It's one thing to block all IP's and then manually enter in what you need, but my understanding was that if you use a dyndns name you don't have to manually enter each and every IP. It worked fine before I updated Elastix to 2.4 but since then no dice.
So is there any other software anyone knows of or about that might work?
Thanks,
amphibian
It is not probably what you are looking, but I use Untangle almost for everything related....
The problem is that you need another machine for that to work, but I believe is a more suitable solution than csf in most cases.
Regards,
Cladio
soborno,
Thak you Sir, I will check that software out. I appreciate the input.
amphibian
