Spectralink 8440 Wireless Phone
Alphabetic
3CX MVP
Hi All,
Has anyone had any experience using Spectralink 8440 handsets on a 3CX system?
Any success?
I'm looking to test these handsets on a local 3CX install as their current (Wave IP500) system with these handsets isnt very good.
regards.
Yes I have successfully deployed these a couple of times.
You can download generic provisioning templates online but manual configuration is fine also.
What I would say however is be selective of the WiFi access points you are using also, Spectralink have a supported list albeit I used s non supported AP, this config is just as important as the SIP side of things.
[email protected].
