Spectrum Caller Id Fowarding
dkeeler
Hi Dan,
Is the behavior you are seeing identical, please advise - is it outbound caller-id ?
Historically I know for outbound caller-id issues can arise if a provider places your number range together under one port request (called a bulk port) and moves to another carrier.
Once the port occurs the new carrier now has these numbers under the provider's name and may be passing that name along.
Have you actually run a trace to see how the caller-id is being sent, if you can describe the call in detail I can provide you more information.
I think there needs to be confirmation that Spectrum actually supports this, and from which field, the outbound caller Id is taken.
megalmazan
