SQL Server Export Error Event ID 50032
ewebster
I am receiving the following error when exporting to SQL Server.
Data transferring to sql server failed due to the following reason: Failed to export `public_cdroutput`: Exception while reading from stream
I have attempted to purge call records to see if that would resolve the issue, but that does not appear to be working. When I try to purge call log files older than one month, there is no change in the call log size, which is currently 24.6 GB. Additionally, the initial SQL Server sync appears to have only pulled in a few months of call logs from last year.
Any insight would be awesome.
Is it possible when you are out of office hours to press the option "Optimize Database" and once it is finished to try and offload again?
Thanks for the recommendation, I will give that a try this evening, and follow up on the results.
Reactions: TheodorosG_3CX
Unfortunately, I am getting the same error.
@ewebster can you please open a ticket with us and then we can take it from there with logs.
amazingbv
