Solved SSH access to Azure instance?
relion
What is the default admin username created by PBXExpress for Azure?
I tried using "admin" but it's not working. When I try to reset the password in Azure, it says specified user account (admin) is not allowed.
Thank you!
During the creation of the instance the ssh password for the user pbxexpress will be set to the same password as the login to the 3CX management console. Change the SSH login password after the PBX has been created and use pbxexpress as user to login.
"pbxexpress" is the username. Got it. Thanks!
Mr_IT
