SSL cert renewal failed on 3cx v. 16.0.6.641
massimo_mic
after update 3cx to version 16.0.6.641 Ssl certificate renewal Failed on Microsoft Windows 2008 R2 server (i receive a warning message this OS is no longer suppported by 3cx but all function work fine to this moment), is a OS problem ?
log indicate this:
SL Certificate renewal has been failed. Error: Internal.Cryptography.CryptoThrowHelper+WindowsCryptographicException: Operazione richiesta non supportata. at System.Security.Cryptography.CngKeyLite.SetKeyLength(SafeNCryptKeyHandle keyHandle, Int32 keySize) at System.Security.Cryptography.CngKeyLite.GenerateNewExportableKey(String algorithm, Int32 keySize) at System.Security.Cryptography.DSAImplementation.DSACng.GetDuplicatedKeyHandle() at System.Security.Cryptography.DSAImplementation.DSACng.ExportKeyBlob(Boolean includePrivateParameters) at System.Security.Cryptography.DSAImplementation.DSACng.ExportParameters(Boolean includePrivateParameters) at PostInstall.CertificateUtils.DsaToDhParams(DSA dsa) at PostInstall.CertificateGenerator.GenerateDhParam() at PostInstall.CertificateGenerator.ProcessCertificatesDirectory(String directory, Boolean temporaryCertificateGenerated, Int32 regenerateNotSelfSignedCertificatesFrom, Int32 regenerateNotSelfSignedCertificatesTo, CloudServerStatus statuses, Int32 regenerateCertificateExiredInDays, String appBin, UInt16 sipPort, UInt16 tunnelPort, Nullable`1 httpPort, Nullable`1 httpsPort, Boolean isPassiveFailoverMode) at PostInstall.CertificateGenerator.RenewCertificates(String appBin, String nginxConfigFolder, String configurationPath)
Hi Massimo,
Please take a backup from your system while you still can, then reinstall a new supported OS and install 3CX again using your backup file (during 3CX Setup wizard).
We do not test older OS versions so unfortunately any incompatibilities will not be detected or fixed in this case.
If you want to keep your old OS, then I would suggest creating a VM and installing 3CX inside the VM with a supported OS at least.
[email protected].
