SSL Certificate Renew
jtomas
Forum User
I'm having issues trying renew the ssl certificate on V20 and I need help.
I'm using the same method that I used on last time (last year) on V18. I did convert both the certificate and private key to PEM and replaced the old one but when I run the nginx command to restart the services it show me an error.
Be helpful to know the error..
Job for nginx.service failed because the control process exited with error code.
See "systemctl status nginx.service" and "journalctl -xeu nginx.service" for details.
Run systemctl status nginx.service and see what the errors is.
Follow de error on the log messsge below
root@PBXDSI02:~# systemctl status nginx.service
× nginx.service - A high performance web server and a reverse proxy server
Loaded: loaded (/lib/systemd/system/nginx.service; enabled; preset: enabled)
Active: failed (Result: exit-code) since Mon 2024-05-13 15:00:57 WAT; 14s ago
Duration: 30min 57.473s
Docs: man:nginx(8)
Process: 93131 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=1/FAILUR>
CPU: 12ms
May 13 15:00:57 PBXDSI02 systemd[1]: Starting nginx.service - A high performance web server and a reverse proxy serv>
May 13 15:00:57 PBXDSI02 nginx[93131]: 2024/05/13 15:00:57 [warn] 93131#93131: duplicate network "::0/0", value: "0">
May 13 15:00:57 PBXDSI02 nginx[93131]: 2024/05/13 15:00:57 [emerg] 93131#93131: SSL_CTX_use_PrivateKey("/var/lib/3cx>
May 13 15:00:57 PBXDSI02 nginx[93131]: nginx: configuration file /etc/nginx/nginx.conf test failed
May 13 15:00:57 PBXDSI02 systemd[1]: nginx.service: Control process exited, code=exited, status=1/FAILURE
May 13 15:00:57 PBXDSI02 systemd[1]: nginx.service: Failed with result 'exit-code'.
May 13 15:00:57 PBXDSI02 systemd[1]: Failed to start nginx.service - A high performance web server and a reverse pro>
lines 1-15/15 (END)...skipping...
Docs: man:nginx(8)
Process: 93131 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=1/FAILURE)
CPU: 12ms
May 13 15:00:57 PBXDSI02 systemd[1]: Starting nginx.service - A high performance web server and a reverse proxy server...
May 13 15:00:57 PBXDSI02 nginx[93131]: 2024/05/13 15:00:57 [warn] 93131#93131: duplicate network "::0/0", value: "0", old value: "1" in /etc/nginx/sites-enabled/3cxpbx:16
May 13 15:00:57 PBXDSI02 nginx[93131]: 2024/05/13 15:00:57 [emerg] 93131#93131: SSL_CTX_use_PrivateKey("/var/lib/3cxpbx/Bin/nginx/conf/Instance1/pbxdsi.ucall.co.ao-key.pem") failed (SSL: error:05800074:x509 certificate routines::key val>
May 13 15:00:57 PBXDSI02 systemd[1]: Failed to start nginx.service - A high performance web server and a reverse proxy server.
Some issue with the private key... is it present with correct permissions and name?
Run nginx -t and see if there is more details.
Reactions: Alphabetic and jed
You're right. The private key was wrong. One I use the corret private key the situation was solved.
thank you so much for helping me!
Reactions: jed
ARKC
