SSL Certificates and Chain of Trust
Kevin Attard Compagno
Staff member
3CX Support
Background information for configuring SSL Certificate files correctly.​
We regularly see questions about error messages relating to SSL certificate issues - typically that your certificate is not trusted. In most cases, the root cause is that the certificate file contains only your server's certificate.
Thx for posting this! What also helps me to find the root couse of the ssl problem is this ssl checker where you can use alternative https ports (5001 or something else): https://www.geocerts.com/ssl-checker
WinSip
